Hello, I'm new here and would appreciate any advice.
I have a Gravely 1840 ZT mower that needs the engine replaced.
The spec number of the kohler engine is SV540-0023.
I have found online an engine with a spec number of SV540-0002.
I called the company and they said that the -0023 and the -0002 were basically the same engine and that the -0002 was made for a Husqavarna mower instead of Gravely.
Is it possible to use this engine as a replacement for the Gravely?
What specifications do I need to look at to see if they are in fact the same engine?
Thanks in advance for any help
