firemediceric
- Apr 15, 2013
- 8
- 21
I'm having no success getting a response in the Gravely area of the forum. Maybe I'll have better success putting it to a wider audience?
I have a roughly 10 year old Gravely Pro Master 320 HD with a 60" deck. Can anyone tell me, or better yet point me to some printed information, what to use for hydraulic fluid? Also, in what position should the deck be when I look for the fluid level on the dip stick?
I purchased an owner's manual, but no where in the manual do I find the information. I stopped in to my local dealer and he just off the cuff told me "Mobil 1 oil." When I asked about the position of the deck when checking the fluid he looked at me cross-eyed. I pointed out that a lot less fluid will be in the reservoir when the hydraulic rams are fully extended versus when they are fully retracted. That seemed to be a new thought for him. His reply was to have the deck set "half way." He didn't instill a lot of confidence. I sure don't want to do damage to the hydraulics by using the wrong fluid, by putting in too much, or by not having enough in the system.
Thank you.
Thank you.
