Gravely 2350
todrich
Yes I can jump start it. It has a new battery and a new starter.
todrich
Yes I can jump start it. It has a new battery and a new starter. I will only turn over about a half a round by it self then lock up. If you take the plugs out it will spin.
Not what I mean. When you jump start it directly to the starter, will it still stop? If it does then it is an engine problem. If it spins through normally then it is a tractor electrical problem.
todrich
When I try to start directly from the starter it still wants to stop turning.
This is getting confusing, because there are two posters trying to get answers at the same time. Todrich, you jumped this tread, and I can't help akranch and you at the same time. If you have the same problem, read what is posted for akranch please. Once his problem is solved, maybe yours will be also.
