Gravely 2350
akranch
I have a Gravely 2350 (0 turn) mower. It seems to not get enough power to turn motor over. It turns 1/2 rotation then stops. It is like the motor is locked up but I can spin it. I have bought a new solenoid, battery, and starter. Still not help. Any suggestions???
If it is an OHV it could be the camshaft. It has a mechanical release on it that seems to fail often. It's job is to slightly open valves during start to allow pressure release.
You don't say engine model and numbers. Would be good to know if you are looking for answers. Different engines mean different solutions.
akranch
Engine Model # SV720S
When I pull the plugs out, it will turn over. But not when plugs are in.
akranch
I adjusted the valves and still not starting.
Did you try it before you reinstall the valve covers to see if it always stops at the same point? Did you set all four valves at .004"? If you turn the engine over by hand were each of the valves opening at the proper time, including a slight opening on compression release?
akranch
yes i did.
Can you try this. Can you jumpnthe starter directly with either another battery or battery charger. This way we can determine if it is an engine problem or an electrical problem.
