Grasshopper mower battery issues
I totally understand you, I had the same problem. I arranged some nice flower beds last spring with tulips and roses and I got the flowers from an online flowers free delivery and then I had problems to use my latest GH mower.
I bought a new one then which is better for my needs.
But I had luck that I never had any problems with the battery :)
I'm Not following you... What are you saying, that you "totally understand "...
:smile:KennyV
[QUOTE .check the pos. batt. cable to make sure it's not touching the frame where it bolts into the pos. side of the batt. russ[/QUOTE]
Thanks, Russ. I had a battery going dead very fast, i realized the positive wire was touching the frame, I rerouted it and voila, 7 days later the mower started right away.
