CajunCub
- Mar 29, 2011
- 182
The manifold is a bank of hydroic controls...as a mechanic, I worked on alot of back hoes & that is what the line of control levers are called, I just called it that out of habbit. So, the valve is what I was talking about.
If you turned the pump, and fluid came out....look to another problem like the fluid motor it's turning or the cylinder that won't work, ect. Maybe the pump is ok....but yes, you could take it and have it rebuilt locally.
