Uncle Bannerman
- Jul 7, 2012
- 1
- 2
First off, this is my first post here and this seems to be a very well organized site with great admins. Now for the question. I have a grasshopper 928d2 circa 2003 that has encountered a starting issue. When you turn the key to start, it fires up normally, but when you let go of the key and it falls back to the ON position, it shuts off. If you hold the key to start, it will continue to run but the starter is engaged the whole time, which is bad. Thoughts? I replaced the ignition switch about a year to year and a half ago. Would it go bad so soon?
