After replacing the upper shaft seal and breather plate and gasket I thoroughly cleaned the oily mess. After mowing a couple of hours I can see a new oily mess from what appears to be a leak at the governor shaft seal. After watching a couple of YouTube videos it doesn't appear to be a particularly difficult job to replace the seal - the worst part might be removing and replacing all of the "stuff" to get to the seal. In addition to being careful to get the alignment correct between the shaft and shaft arm, and cleaning the shaft thoroughly to protect the new seal, are there other caveats I should be aware of?
One video specifies a seal part number 92049-7019, but he never says what model Kawasaki he has. Mine is FH580V-AW00. Would his p/n work for mine?
Thanks
Thanks
