I have a Kawi FD501V twin cylinder liquid cooled on a JD LX279. I've had to replace a number of things, to include the carb. It was running very rough and the jets were seized inside and I ruined the jets getting them out so I replaced the carb. I've replaced the voltage regulator that was bad (not charging). New PTO also. Engine RPM's were not an issue before.
Now when I engage the PTO it drops about 1000 rpm. It will also struggle when going uphill, the governor is not compensating. I have reset the governor correctly. I'm afraid I may have stretched the governor spring slightly during the carb replacement.
Could a weak governor spring be the cause of the governor not compensating for the power draw and causing the RPM's to drop? Is there anything else I should be looking at?
