governor linkage
wdunlap1
First off, Hello to all. First post here. So thank you in advance for the help I may receive.
I have a Husqvarna mower GTH27V52LS with a Briggs 44q777 engine.
I lost the linkage that goes from the governor to the butterflies on the front side of the carb. I have ordered what I thought was it, but the one I keep receiving is too long. My question is does anyone know the length of that linkage itself. My idea is to use one that I got that is wrong and cut it to length. All the bends appear correct. Any help or ideas are appreciated. If I need to post a pic of location Ill do that. Cant right now. Thanks
When you order the linkage you need to use the entire engine number
So it should be 44Q777-1234
The 1234 is very important because that is where the different throttle controls will code to
So to give you the correct answer , assuming that the engine belongs to that mower we really need the 1234 bit and the -?? won't hurt either
Plus the serial number, which B & S call the "date code" in their parts books because if they changed the throttle linkage length it will be as of date code yymmddxy
And look there is all these variation of the 44Q777.
