Jinzo Ningen
- May 27, 2011
- 127
I DID turn the key to the left to the pre-heat cycle, counted to 10, then turn the other way to start. Motor just cranked & cranked but would not start. Good fuel, full charge on new battery, but nothing. A few days later when the temp was above freezing I followed the exact same steps and it started just fine. That's why I wondered if there was a chance the glow plugs were bad. It hard to tell about such things during the summer season when the temp is 70 and above. I asked about plugging the engine in since my '84 F-250HD diesel pickup had a block heater with a 120v pigtail hanging out the front grill to plug in - there is no such thing on this mower.
Not crazy about trying to force it to start with fluid or other bypass/cheater "tricks" - the mower should start & function properly without coercing it.
reynoldston,
I prefaced my original post by stating it might sound like a dumb question. Even so, I really don't appreciate being basically told I don't know my 'A' from a hole in the ground.
reynoldston,
