RetiredGuns
- May 25, 2014
- 146
Kind of funny how this thread morphed into what blades to use and throttle speed. Threads tend to do that though...
Turbo, would you mind sharing pictures of you discharge chute modifications?
Thanks.
I cant believe people still use their chutes.. First thing I pulled off.
This is what Toro says on the subject:
What are the benefits of running your riding mower on full throttle?
-Cleaner cut on the grass
- More power, less likely to bog down
- Less stress on the engine
- Engine runs cooler
- Slow engine speeds can result in hot spots on the cylinder
In addition, many of these machines have hydrostatic transmissions that generate heat during operation. They have a fan that keeps them cool and the fan is driven directly by the engine. Running the engine less than full speed will frequently allow the transmission to overheat. The first sign is usually a lack of power on hills. Permanent transmission damage can result. By keeping the engine at full speed the operator will keep the fan at full speed. This will maximize the air flow for the transmission keeping it cooler and preventing premature failure.
Riding products should be at full throttle at all times.
