mhavanti
- Oct 12, 2014
- 924
Ronno,
I agree with that as long as the two gears are sitting at a ninety degree angle to each other and you both probably do have a ninety degree set up. All I've had in the shop have had the 12 degree angle pinion with the turned pinion gear. I assumed his gear was the same and thus, my information other than the plastic bushing helping to remove the climb of the fan gear would then be incorrect.
Try not to get too hot down there this morning.
Its hot in Misery today.
Or, Missouri to those that aren't in the know.
Max
Max
