Re: General Transmission Element V Service Manual (Rotating Cam) replacement.
Ok...I got it fixed. Took a while hunting for the part (rotating cam) at General Transmissions...had to talk to like 4 different people before I got hold of someone who I think is an applications engineer. Anyhow, he found the part and asked me to send him my address. He sent an email to me first...I responded with my address and he sent it to me for $13 COD...I didn't ask for the special tool that slips over the shaft pin...it was near impossible to break the nut free...ended up getting it with a very large vice grip and a 7/8 wrench...it was a bear though. If you need to replace the cam...make sure to ask for the special tool...I broke a screwdriver and a punch before trying the vice grip approach. I have the guy at GT's email if someone is in the same boat...could save you a few phone calls...just respond here that you need it and I'll email it to you. As for replacing the cam...I disconnected the battery, a couple of electrical plugs...the drive bar and the brake spring (a couple of cotter washers and pins had to removed. From there...there were six bolts that held the trans to the frame (all of them 1/2"). I took those out and jacked up the rear at the tow connector. The trannie rolled a little forward so I could disconnect the main belt. Next I just picked up the rear of the tractor and rolled it forward and out of the way. To get to the cam...I followed the video on the GT site...didn't even have to take out the second pulley off...just the one with the pin I mentioned before...once the black cover was off, it was super simple to replace. I put it all back the way I dissembled and fired it up...worked like a charm for a couple hours worth of my time and $13!!!
