Here some info I got when I was working as a small engine tech. Yeah we did a lot of generators and some the had old stale fuel so the carburetor work was part of that work.
By the way Most potrables are two pole generators, but RV generators are 4 pole with larger engines and less noise.
Most generator failure were caused by overloading OR backfeed when the power came back on. Usually toasted the stator and was too expensive to repair
Hope this helps.
CARBURETOR REBUILD KITS / SOLENOIDS
CARBURETOR REBUILD KIT SOLENOIDS
046963 OBSOLETE 046042 ***********
072530 OBSOLETE 074050 ***********
0851100146 0851100232 ***********
0921340125 0921340123 ***********
073112B 075252 089870
0A4600 0A46000ESV ***********
0A6562 0A46000ESV ***********
0C1535AESV 0C1535ESV ***********
0C8526 0C85260SRV 0E0485 (SINGLE WIRE)
0D80590ESV ********** 0F1932
0E25480ESV 0E8000 0E5551 ( TWO WIRE)
0E3291 0E8000 0E5551 ( TWO WIRE)
0F8603 ********** 0E5551 ( TWO WIRE)
0F9035 ********** 0E5551 ( TWO WIRE)
