Export thread
Gday from down under
#1
C
chainsawnut
Hey I'm Pete alias chainsaw nut I collect chainsaws brushcutters and fiddle with lawnmowers at times.
I have a self propelled masport slasher powered by 8 hp briggs,a victa 160 more known in australia than elsewhereand a couple of briggs powered rotary mowers.I received an invite to this site via tractorbynet which is a gereat place to visit.I am self taught when it comes to small engines and have a lot to learn,I often don't understand what I have done to make something go elimination or fluke I'm not sure which.anyway I am looking forward to enjoying the site cheers
#2
Two-Stroke
Two-Stroke
...I often don't understand what I have done to make something go elimination or fluke ...
Hey Pete -- I can't understand the above comment but welcome you to this forum.
I'm into chainsaws much more than mowers myself so we've got that in common.
There's another Australian member -- "lizard" from Perth -- that I haven't heard from in a while. I hope he gets back on here soon.
#3
K
KennyV
Yes it;s good to have another from from down under... Glad to see you here Pete...
You are right about lizard .... have missed his fast mowing posts... He was generally here around this time of day...
Hope he gets back... :smile:KennyV
#4
C
chainsawnut
What I meant by elimination was I keep trying different parts until something makes it go BRmmmmmmm and down here fluke is a slang term meaning lucky
#5
BKBrown
BKBrown
Welcome !
There ia also a "digger oz" fairly new member from australia.
#6
173abn
173abn
howdy Pete,knew some Aussies and New Zelanders in Nam.Great folks you are. russ
#7
Two-Stroke
Two-Stroke
Thanks, Pete -- we use the term "fluke" the same way also and I now understand what you are saying.
One interesting bit of knowledge I picked up from lizard is that, in West Australia, they use expensive reel mowers on finely groomed grass and achieve a very close cut: less than 1/2 inch. They groom whole lawns more carefully than people here (Southeast USA) groom putting greens on golf courses. Is it like that in South Australia?
#8
C
chainsawnut
Hi all spent ages typing a reply to this and cant post it message was **************** now I cant remember the message
#9
C
chainsawnut
Ok that one worked ,the reel mower you mention would have been a Scott Bonnor bit of an Icon out here in earlier years,not so common now ,Mr bonner of scott bonner fame lived out his last years here in Victor harbor.A friend of mine used to cut his widows lawn with one of his old mowers.Mostly I see rotary mowers in use usually with briggs a stratton powerplants.The other mower Icon and it is a bit of a legend is the victa Mostly 2 strokes even had a horizontally opposed twin cylender version.They made a great high rear arch model that was great with wet grass,I used them when I had a lawn mowing round ,The good thing about two strokes was you could maintain and fix them at home.If they had spark,fuel and compression they would go eventually cheers
#10
Two-Stroke
Two-Stroke
The mower lizard uses is a Dwyer Felton -- made in Australia.:thumbsup:
One of the most rambling and entertaining... and possibly the longest (25 pages) thread on this website is this one -- started by lizard.
#11
K
KennyV
This should be toward the end of mowing season for lizard... so he may have the time to make it back, and pick up his old thread... :smile:KennyV
#12
C
chainsawnut
Hey It was a good read I have a mix of sant anna and kaikuu cant kill either of them water them in summer with grey water from the washing machine ,last couple of years we have been under severe water restrictions and it was a big fine if you used a sprinkler on any part of your garden.I tend to keep my lawn at around one and a half inches saves on water longer grass seems less prone to drying out,Water restrictions have been lifted over recent times but water saving methods learnt in hard times have stayed with me.I t was so bad our state has been building a de salination plant and water can only get dearer
