This engine is on my logsplitter, probably has some 150 hours on it. It was running fine until I tried to use it recently. It started fine as usual, but after a minute it quit. Started right up again, ran for a minute normally then died again, suddenly, as if fuel was lost. I began by making sure the fuel was fresh and reaching the carburetor. I then cleaned the carb per you-tube tutorials, twice. No change. So I bought a new carb and installed with new gaskets. No change. Started but died after a minute or two. Decided to check out everything else I could think of. Coil was checked and clearance reset, though it seemed very close. When I checked the valves, lash was good but exhaust valve was broken. It closed the valve but was weak. I thought aha! and ordered and installed new spring and reset lash. No change. Checked compression by cranking 3-4 times on my guage screwed into spark plug hole. It was 71# which I believe is good. I tried this several times to be sure. The governor seems to be working fine, and I checked that that little adjustment was fully to  clockwise position. Oil is fresh and full. I tried unhooking the kill switch wire from the coil but no change. I tried removing gas cap while it ran to make sure cap was breathing. No help.
Last attempt was yesterday. It actually ran for 3-4 minutes so I threw a log on and the moment the blade touched the log it died, apparently did not like the load. However, it started right up again, ran a few minutes and died. I am ready to give up without new ideas, and buy a new engine for it. Hoping to avoid that as it seems to be basically ok and I may just be missing something.
Sorry for such a long post but wanted to be clear about what has been tried already.
Thanks in advance for any ideas.
