Hammermechanicman
You should put in Old style spindles just to buck the system.
LoL.
LoL.
So true......the down side of thisis you will need to buy the blade from them & not Amazon or ebay and that appears to be against the religion of a lot who post here.
Excellent results would be bagging IMO.I've been using Oregon 598-064 Mulching Gator Blades for three years with excellent results in my ZT1 50" deck. The blades sit just a tad lower to the ground but not too low. I thought I would have a selection available by now but this and two offered by CC are it, as far as I know
Bill
They might last longer too. LOLYou should put in Old style spindles just to buck the system.
LoL.
Well thats good to know! Price is not too bad. Is the shaft a press fit on bearings? Or slip?Actually all you have to do is change out the spindle shaft.
No. The ones I use fit perfectly as they are an OEM replacement.Is there any problem with the offset using the Copperhead 16080 blades?
