Gaskets?
reynoldston
wouldn't hylamar ultra black be good for that? ive used that for kohler magnum series halves
When you buy your gasket material it comes in different thickness and types. I don't know how the crank case is put together, what it is made of, or if you need any clearances. I have seen some cases put together with shims and then some without any gaskets that uses anaerobic sealant. Being a 2 cycle engine this could well be there isn't any gaskets?
abelw44
Hello all,
Thanks for all your ideas. I will try using cardboard for now and see what happens.
In the UK we have a chain of parts stores called "Halfords".
Thanks Abelw44
