gasket
Which parts need sealed? Without knowing, factory paper gaskets seem to work ok.
Scrubcadet10
Moderator
Staff member
for the 2 F series engine diagrams i found, i haven't found a gasket being shown.......
dougmacm
The "F" engine case haves are sealed with Anaerobic Gasket Maker (no actual gasket as others stated).
Lawn Boy Mechanic Handbook calls out Lawn-Boy Gasket Maker # 682302.
I used Permatex # 51817 when I did two of my "F" engines.
Doug
dougmacm
Yes, that is what it says in the Mechanic Handbook. If you don't have one of these books, pick one up or download it if you can find it.
Doug
earnest t bass
Doug
is this product heat resistent or does it matter?
dougmacm
It is designed for use in assembling engines, and I'd guess it is the equiv. to the O.E. L-B stuff so I'd say YES.
Go to an auto parts store or google it and read the packaging.
Doug
