Gas tank removal
ak2stepin
Unable to remove gas tank on craftsman push mower model 917377582 Seems to be a fastener i can't find. No luck utube.
Auto Doc's
This shows to be an older model. Can you provide a couple of pictures? That may help us help you. As near as I can tell, this is a Briggs and Stratton engine. If that is the case, there will be numbers stamped on the engine valve cover.
Sears did not manufacture their mowers, they were private labeled by others who actually build them.
sgkent
a Google shows this for that model. Click on the photo to see it better.
And not one visible screw or screw hole. Your FIRED!! My best lame Trump joke. LOL
Tecumseh has a habit of requiring the tank to be twisted away from the blower housing and then pulling up out of the locking slots.
ak2stepin
Thank you. I was able to figure it out.
