Hi
Im new to this forum and hopeful I can find some help for an elderly friend of mine. I know next to nothing about mowers
My friend has an older craftsman ride on mower with a Briggs & Stratton 12.5 HP motor. Sorry I don't know the model numbers...
The problem he is having is that after starting it runs for maybe 20 seconds before gas starts to overflow into the filter and then the motor cuts out.
The gas seems to be coming through the vacuum line that is attached to the cover over the valve springs.
This is what I have tried
I also took of the valve cover to check for a stuck valve but the intake and exhaust valve open and close as I rotor the engine. It also appears that they are closing properly. There was some carbon buildup.
Can anyone help with diagnosing this issue and a possible fix?
Thanks
Dean
- Installed new carb
- New fuel filter
- New fuel shutoff valve
Thanks
Dean
