Tinkerer200
- Mar 14, 2015
- 913
Anyone who refuses to install an inline fuel shut off because of a new float needle, seat, NEW CARB, whatever and use it is being foolish. I have been at this for about 65 years and well speak from experience. Call it a band-aid if you wish, I call it being foolish to not use an insurance device. The local salvage yard is full of engines whose owner or repair person thought they knew better. You think your repaired carb will never leak is your repair better than the carb was when put out new? Do the carbs put out new ever leak? IF they never leaked then there would be no point in putting out repairs. Any repair person should know there is a constant possibility of small foreign particles getting under the float needle. These problems are much more prevalent today because the EPA made the mgf,s do away with the weep hole originally put in specifically to prevent oil contamination.
Walt
Walt
