Are there other reasons beside a leaking carburetor for gas to be in oil? Blow by? Leaking gasket?
Q quasaronly Forum Newbie Joined Jul 6, 2014 Threads 3 Messages 4 Jul 6, 2014 / Gas In Oil #1 Are there other reasons beside a leaking carburetor for gas to be in oil? Blow by? Leaking gasket?
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,424 Jul 6, 2014 / Gas In Oil #2 Object moved click anyway Category-troubleshooting-repair then enter gas in oil.
Chevychopper Member Joined May 29, 2014 Threads 3 Messages 40 Jul 7, 2014 / Gas In Oil #3 quasaronly said: Are there other reasons beside a leaking carburetor for gas to be in oil? Blow by? Leaking gasket? Click to expand... Sounds like you may need to clean the carb, usually when this happens. There is some type of debris in there causing the carb bowl to overfill and flood into engine.
