Q quasaronly Forum Newbie Jul 6, 2014 #1 Are there other reasons beside a leaking carburetor for gas to be in oil? Blow by? Leaking gasket?
M mechanic mark Lawn Pro Jul 6, 2014 #2 Object moved click anyway Category-troubleshooting-repair then enter gas in oil.
Chevychopper Member Jul 7, 2014 #3 quasaronly said: Are there other reasons beside a leaking carburetor for gas to be in oil? Blow by? Leaking gasket? Click to expand... Sounds like you may need to clean the carb, usually when this happens. There is some type of debris in there causing the carb bowl to overfill and flood into engine.
