Needle & seat in carburetor not sealing properly. Remove & disassemble carburetor to find problem or replace carburetor. Install an inline fuel cutoff valve to prevent future problems or use the fuel cutoff in carburetor, if present.
Sorry just saw that you already replied to him
I didn't see your post AGAIN LOL
You might try reading the replies before posting. LOL
Get a new carb. Carb for that model runs around $19.The needle and seat are not sealing right. you will have to open the carb up and fix that or get a new carb.
... and change the oil.
