Gas Capacity
Can probably find another gas tank off an old brigs or something bolt it on drill a hole into current tank and run a hose between the two. Would give.you more capasity won't look pretty tho
I fill mine mostly to the top. If you fill up then wiggle the mower it seems the fuel level lowers. Possible air pocket?
