exotion Lawn Addict Joined Jun 24, 2012 Messages 3,444 Oct 3, 2013 #11 Can probably find another gas tank off an old brigs or something bolt it on drill a hole into current tank and run a hose between the two. Would give.you more capasity won't look pretty tho
B Bobcatjerry1 Forum Newbie Joined Sep 21, 2013 Messages 3 Oct 4, 2013 #12 Thanks for the input! I will fill it to the top:smile:
S stygz Well-Known Member Joined Apr 26, 2012 Messages 127 Oct 12, 2013 #13 I fill mine mostly to the top. If you fill up then wiggle the mower it seems the fuel level lowers. Possible air pocket?
lawn mower fanatic Lawn Pro Joined Jun 8, 2012 Messages 6,749 Oct 12, 2013 #14 stygz said: I fill mine mostly to the top. If you fill up then wiggle the mower it seems the fuel level lowers. Possible air pocket? Click to expand... Yes I notice the same thing.
