Garry
Garry rausch
Have an mtd pro 6 hp. Set for 4 years. Replace carb. Plug. Primer. Cleaned fuel lines. Will only idle
6 hp pro what It this a snow thrower, lawnmower, logsplitter, tiller, weedeater, Lets start with the actually model number of the item from the tag and if possible the model information from the engine tag.
Garry rausch
Looks like the 122K02-0337-E1 engine. Is the governor spring present and connected
Item 209a is this diagram
Hooks between the loop in item 202 and the eye in this item
You were spot on checked spring. When I replaced carb of hooked up spring wrong causing there to be no tension on the spring. Mower fired up and ran well. Thanks so much
