Garry rausch
- Sep 21, 2022
- Threads
- 3
- 6
Have an mtd pro 6 hp. Set for 4 years. Replace carb. Plug. Primer. Cleaned fuel lines. Will only idle
www.partstree.com
You were spot on checked spring. When I replaced carb of hooked up spring wrong causing there to be no tension on the spring. Mower fired up and ran well. Thanks so muchLooks like the 122K02-0337-E1 engine. Is the governor spring present and connected
Item 209a is this diagram
Hooks between the loop in item 202 and the eye in this item![]()
PartsTree - Home of OEM Parts for Outdoor Power Equipment
We are committed to providing you with the largest selection of OEM parts from the best brands, the best diagrams and part search tools anywhere.www.partstree.com
