Thanks for the response, & the Idea, .......hmmmmmmm.....I'm chewing on that now.....well (not meaning to argue, just discussing)....with the weight of the front deck & the weight of me, motor,trans, on the drive tires on a 28* bank its gone'a slide down, (I just happen to be at the bottom of the ditch anyway),..... pinning the rear crazy wheels will not allow me to steer a little to keep the left side of the deck from digging into the bottom of the ditch.   I've moved that front left anti-scalp wheel over one hole then drilled another hole, that put the wheel on ~ center line with the side of the deck & that helped some. I wanted to put a anti-scalp at the back on that side but never got around to it. That may have helped, but didn't think that would totally solve the problem.
Even on a 20-25* bank I have to crab just a little or it want stay on course.
Another thing I was concerned about, was not knowing how well the oil pickup is submerged at that angle!   Even tho I've watched the oil light ( idiot light ) while mowing at that steep an angle & it didn't come on, I don't put a lot of trust in those.
