They are original replacement parts, the problem I'm having is getting the gromet and stem up in the tank. It is such a tight fit, can't get both in together, I tried the gromet first, then the stem, and then both the gromet and stem together. I don't want to put too much pressure on the stem, that's how I broke it to start with,any suggestions? I've tried axle grease
