Repairs fuel tank connection
JTT
Guys, I'm having a problem getting the gromet and stem back in the fuel tank on a Husqvarna RZ5426 zero turn, can anybody help?
They are original replacement parts, the problem I'm having is getting the gromet and stem up in the tank. It is such a tight fit, can't get both in together, I tried the gromet first, then the stem, and then both the gromet and stem together. I don't want to put too much pressure on the stem, that's how I broke it to start with,any suggestions? I've tried axle grease
On all tanks I have worked on the grommet has to go on first,then the fuel stem. Tight fit yes but, that is what seals it up. Perry
Finally got it, had to remove tank, turn it over in order to put enough even pressure to insert grommet in first, the stem, actually pretty easy this way.
