Fuel Starvation
Hey Jag I am having a similar issue as you. Were you able to resolve your issue by doing the steps mentioned? If not, what was the fix?
I installed a new carb and assumed that the seat would be fine but I guess it may not be after all.
Thanks
Brian
From Amazon/Ebay?
China?
Shouldn't take 20 primer pumps to fire the little fella up. Sounds like the primer is failing.
Remove the fuel bowl. see if fuel runs out all over the place. Of if the carb has a drain screw, remove it.
Blow the tank out in reverse order of fuel flow. Should be free and open. Get all the grit, grass and dirt out of the fuel tank while you are there.
