Fuel solenoid wire
Mink man were you a trapper at one time ??? I was till the fur prices went from 40 to 50 bux for a bull mink then to 10 bux ..........
Any way just cut the 2 wires at the insulation and put a butt splicer on each one, then fill each end with silicon or something so you don't have a problem down the road........
Your engine will run fine without the solenoid on the carb.............
Let us know Mon Ami ~!~!
Yes a trapper for many many years. Love the mink, easy to catch,skin and put up. Now I mostly just hunt Coyotes. Thanks for the reply, those butt splicers may be the ticket.
Google your engine and after you put in parts it will bring some things go to parts tree and make sure your looking at your numbers and in the electrical look for your harnes then put the numbers in google and search for the pics
