shurguywutt
- Jul 17, 2013
- 24
- 147
I am looking to add one to my Timecutter. Which type do you all recommend and should I put it before or after the fuel filter?
Even with electric fuel pump ?The float needle valve and seat can still leak fuel all over the place.
Then you never work on a ZTR. Many of them have the fuel line coming out top of tanks. I even work on a few JDs that the electric fuel pump was in the fuel tank. I even a couple riders with the fuel line coming out of the top of tank.Never seen a fuel supply come from the top of the tank , you may be looking at a return line
No, it is the supply line, & Shut off valve is there as well.Never seen a fuel supply come from the top of the tank , you may be looking at a return line
