Fuel shut off valve or buy non-ethanol gas?
I agree, but if he has never replaced the needle/seat, the problem is going to continue. In my opinion, the best way to prevent it reoccurring is to start using non-ethanol fuel. It's worked for our customers for the last three years. I know that Carscw doesn't agree, but it works for us and when you are in the service business you do what works for you.
Yardguy
I suggest that you pull the carb off one more time and give it a good 24 soaking bath or have it ultrasonically cleaned. When you reassemble it, install a new float needle and seat. You don't give us an engine model number, I'm assuming that the part number is 398188. After you got everything back together, I recommend that you use non-ethanol fuel. This is what we recommend to all our customers who have this problem.
Thanks much for the guidance. I don't know what the engine model number is but I'll find that out and post it if I have more problems and need to ask for more help. I'll find some non-ethanol fuel and use it from now on.
QUESTIONS:
1. If I use non-ethanol gas, would it still be recommended to install a fuel shut-off valve and run the engine until it quits each time after I mow the lawn?
2. do you recommend adding a fuel stabilizer to the non-ethanol gas in the gas can? If so, which one?
Thanks for the professional help,
Yardguy
davbell22602
Another alternative is to buy the Tru Fuel 4 cycle pre mixed gas that has no ethanol in it.
Yardguy
I see this is going to turn into a blame everything on ethanol for the lack of proper maintenance.
The ethanol did not clog the carb up in just 4 weeks.
Actually, reflecting back now, I think the idle time in the mower was more like 6-8 weeks. But the real problem might actually be how long the gas was stored in my 5 gallon gas can. That would be much older, and then when refilling the mower's tank, the ethanol gas is already old + the additional 6-8 weeks it sits idle in the mower's tank.
I also live in a high humidity location so I'm wondering if the ethanol gas in the mower's tank is absorbing water more than normal humidity locations.
I'll only fill 3 gallons in that gas can from now on and buy non-ethanol gas.
Thanks,
Yardguy
Carscw
Actually, reflecting back now, I think the idle time in the mower was more like 6-8 weeks. But the real problem might actually be how long the gas was stored in my 5 gallon gas can. That would be much older, and then when refilling the mower's tank, the ethanol gas is already old + the additional 6-8 weeks it sits idle in the mower's tank. I also live in a high humidity location so I'm wondering if the ethanol gas in the mower's tank is absorbing water more than normal humidity locations. I'll only fill 3 gallons in that gas can from now on and buy non-ethanol gas. Thanks, Yardguy
I will agree 8 weeks is not good.
If your using a additive I would not worry about the fresh start.
I understand why some say to use pure gas. I have had no problems from ethanol but I don't store any gas. I buy my 20 gallons every mourning and use it the se day.
I would rebuild the carb and try the pure gas.
Yardguy
Thought it might be worth mentioning that:
1. Before I bought the John Deere mower in August 2012, I had a Craftsman mower and a "Weed Eater" weed whacker. Never had problems using old ethanol gas in either one. Never used a fuel stabilizer in the gas.
2. When I bought the John Deere mower, I inherited a used Stihl weed whacker. While the John Deere mower had the 3 no start episodes, I never had a problem starting the Stihl weed whacker.
I refilled my 5 gallon gas can with fresh gas and added Stabil to it after the first mower no start episode.
For the Stihl weed whacker, I fill a used one gallon Coleman fuel can from the 5 gallon gas can and add 2 cycle oil to it. I fill the mower with the gas from the 5 gallon can. So the gas in the weed whacker is the same age gas as in the mower except that it has 2 cycle oil in it.
The John Deere mower is the only one that has had the no start problem.
Just adding info to the info bin,
Yardguy
Carscw
Solve the problem and sell the junk Deere
briggs
i use high test only never have a prob but then again my gas dose not sit around for more then a week at a time
