Berniebac
- Apr 8, 2012
- 25
- 180
There is a lot of dodgy fuel line out there.
Every now & then I come across a mower where the owner has used either neoprene ( goes soft & sticky ) or PVC goes hard & shrinks.
Glad to hear you are out in the yard again.
If you feel like it put a match to the end of the old fuel line.
If it starts to burn it is most likely PVC.
If it is genuine Buytl rubber it should char & check.
I will give that a try just to see what it is. I don't recall seeing it cracked or broken down on the inside, but I really just wanted to get it going and out of the basement.
