Fuel leaking from carburettor inlet
nitram2
Fuel leaking from carburettor inlet.
I'm a novice. Troybilt chipper with 10hp OHV Model 205432, Type 0036E1.
Does this indicate a bad float ? If so will I need a repair kit in addition to the float,
before I disassemble ? Thanks
Could be the needle is not sealing and the carb is filling with fuel and
Flowing out of the air filter.
A good clean and possibly a new needle and seat if fitted.
