VegetiveSteam
- Jun 1, 2022
- 2
- 467
Something else to try. Unplug the electrical connector to the coil on the side that isn't firing. Then turn the key to the on position. Turn the key off and check for codes. If you get a code, that would lead me to believe the wiring between the ECU and coil is fine and the ECU is fine. If no code shows, do the same thing on the side that is firing and again check for codes. It may give more questions than answers, but it may shed some light.
