I have a John Deere D170 with a 26 horse Briggs and Stratton engine and it seems to run alright, maybe a little rough but since I ran it out of gas it just doesn’t get hardly any gas in the fuel filter. Being a little obsessive I have changed the fuel pump and the breather tube that goes to the valve cover, unhooked the gas line from the pump on the filter side to see if gas would flow freely from the tank. None of this made it better. And when I say that there’s not much fuel in the filter I mean that there’s barely enough to touch the paper. Should I just blissfully ignore it, maybe wrap the filter with electric tape so I can’t see in it or is there a possible problem?
