I have a Yardman push mower with a 6.5hp Briggs and Stratton engine. It starts then quits, if you keep pushing the primer bulb while it is running it will stay running. I have cleaned and rebuilt the carb. and installed a new primer bulb and air filter. Still wont keep running. Could it be the fuel line or the air breather hose? I've run out of ideas so any help would be appreciated, thank you.
