CrusinSusan
- Oct 19, 2020
- 6
- 44
When you said to remove the rocker covers and do a test run, just start the mower and let it run idle at full throttle with covers off? No blade engaged just running? How long do I let her run? Thank you very much! I can get a bore o scope from my neighbor I’ll check that tomorrow and look for the hatching.The cafine just kicked in ( morning down here )
See if you can get your hands on a bore-o-scope
Shove it down the spark plug hole and look for the cross hatching on the cylinder walls
