PTmowerMech
- Apr 16, 2018
- 397
- 3,023
Rebuilt with RB-100, new fuel filter & primer. Checked the needle lift with the Zama flat edge tool. Bottomed both H and L and opened 1/2 turn each.
At first I noticed it took forever to prime.
It starts easy and idle nicely. At first, it would rev up great. But as soon as you let off the throttle it would die. Then take for ever to crank again. I finally got it adjusted so it doesn't die when you let off the throttle. But when I was adjusting the high side, it runs the same with the high side closed or 2 turns open. About 1.5 to 1/75, it start strokin, so I back it off all the way to close to see if it would sound lean. But not even completely closed.
So does this mean there's something wrong with the L side?
When rebuilding, I was careful about not getting compressed air close to the holes. And only used SeaFoam top cleaner/lube spray on it. Cleaned all the old gasket off, All new gaskets & needle.
Now L is about 1 turn out. H is about 3/4. Response time is down, from when I first cranked it. But it doesn't die when I let off the throttle.
Also, when you gas on it, at first it feels like a V8 with a broken motor mount. LOL
