- Nov 29, 2014
- 64
- 24,702
Great but once you have poured it from the protective sealed environment into the fuel tank all that goes out the window.
Add to that the recirculating nature of the cube carbs ensures every drop gets exposed to a lot of oxygen from the air and heat from the engine.
Which is why if you are not going to use it for more than a month it is prudient to tip the unused fuel out , start the device and run it till it stops .
Weather this is actually necessary will depend upon the chemistry of the fuel, the temperature & humidity of the air and the micro climate where the tool is stored.
And this can be so localized such that a trimmer hanging on one side of the shed will not be affected while the chain saw on a shelf on the other side of the shed will clog the carb every time
