My Stihl weedeater runs fine but won’t shut off.
I have checked continuity from the yellow wire grounded to the motor to the switch and it is good.
I have continuity on the black wire that plugs into the coil and goes to the kill switch, it good as well.
When I push the kill switch down I get continuity between the yellow(ground) wire and the black ignition wire. So the kill circuit is good.
What else should I look for. Maybe the connection coming off of the coil is bad????
I just don’t know.
Any suggestions
I just don’t know.
Any suggestions
