The front right tire is wore down smooth and the left tire was fine but now is wearing down fast. I realize there's toe in/out. Mine toes out about 2". Having the tight turn steering there has been a few times when running it I would be turning tight and hit a rut or hole that would jerk the tractor to a stop jamming the front tires all the way turned. Everything looks normal but could I have damaged something to cause the tires to wear as fast as they did? I would like to replace tires but fix the problem first.
