twall
- Feb 27, 2011
- 78
- 1,628
I wonder if anyone else here has run into this:
My neighbor gave me an old bolens push mower, and it had a 3.5 briggs with an odd rope-pull starter. It was set up just like a modern electric start (with a toothed flywheel, and just a flat screen atop it, like elec. start), but the 'starter' was rope-powered. the rope pulled straight up, rather than in the same direction as the flywheel.
Anyway, I thought the engine was cool - but there was no spark. this mower was from the late sixties, to early or mid seventies. I didn't want to mess around with points, and I has plenty of old B&S around, so I thought about converting it. One problem: How many electric start 3.5hp vertical shaft engines have you seen lately? I was sure the magnets were different on the flywheels from points to magnetron.
For the heck of it, I just swapped the coils. It took off one pull, no further modification required!
Wonder if I can do the same on my '67 Simplicity? Looks like the same setup - and appears that an 8hp coil will bolt right on.......
