From points to solid-state
twall
I will ASAP. The mower is under my trailer, and the skirting is behind a foot of ice and snow.....I warn ya - it's in bad shape.
Murry Furry
Dude no hurt, i think the thought may be better then the image. it is like when you look up to someone, and then when you meet them they aren't what you thought they were.
snapsstorer
by the starter cord pulling straight up, i take you mean that the rope handle was just of the side of the flywheel sticking up out of the top of the cover. if so i have a few mowers that have it that way. the starter rope is rapped around a pulley set up that engages a gear that slides into teeth on the bottom of the flywheel when you pull the starter rope. if you check out some of the old lawnboy's, they have that style starter pulley set up
