Freedom Z starting issues
Lillite
I notice the same problem with my Freedom Z (2007). Every once in a while lately I don’t get rotation when I turn the ignition switch. I replaced the ignition switch on a whim. Right after bolting the dash board back in, my first crank was a fail. Turned the key again and kicked right off. The switches seem to be fine (left and right drive, clutch, seat). I changed the starter solenoid with a newer beefier unit two years ago but I think that may be the culprit. Could be high resistance on one of the control circuits. Going to clean them today.
Also, off topic slightly but, what after market suspension seat fits the 11X11 inch bolt pattern on the Freedom Z?
